3500V6 4X4 jimmy
  • ericjon262
    replied
    you should do it up like a cyclone/typhoon!
  • Guest
    Guest replied
    I might have a 2000+ intake set.
  • Mars
    replied
    Turbo is in the very distant future. I'd be happy to get it to run mid 14's by next summer
    I have my swap engine !
    It's a 3500 that a friend was running in his Sunfire, with an Izuzu trans. (he blew 2 transmissions and a clutch, then gave up on the car). I picked it up for next to nothing and it already had a WOT crank trigger wheel and a 7730 with a somewhat decent harness.
    The only thing I don't like about this motor is it has the "poor flowing" early 3400 upper intake. I'd like to find a 2000+ one for cheap. I will look around.
    That sunfire goes to scrap on Saturday and I'm picking a rotted out Grand Cherokee that is being given to me. (has a Dana44 HD rear and a low pinion Dana30 front with 3.73 gears.) I may go with those axles for now. Ideal would be a 8.8 rear with a high pinion D30 front... Not sure if I should spend extra $$ now to get the axles I want or use the free Grand Cherokee ones. while I wait to find and re-gear some better axles to 4.56.
  • young gun
    replied
    In for results with this one. 11's ??
  • Mars
    started a topic 3500V6 4X4 jimmy
    3500V6 4X4 jimmy
    Just picked it up. has the 700R4.
    have a 3500 ready to go in with a WOT trigger and 7730 ECM.
    Going to do a High Pinion Dana30 front on leafs, high steer, spring over axle and Dana44 spring over in the rear and hopefully run around a 35" tire in the end.
    Tons of pics to come.
    I have a Precision Billet 58mm also, if I get bored... But that is a couple years away..
