Looking to swap a 3.4L DOHC into my Camaro, which was a pushrod 3.4L originally. I have the entire harness and engine from a Lumina (I think, gotta re-check) engine needs a rebuild which is alright, having it re-ringed if I can, else new cast pistons will be used. It will be a lightly boosted engine, probably less than 7psi MAX. Now, question is, will the Lumina ecu interface with my stock v6 harness? When I pulled the motor from the Camaro I lost 90% of the sensors and a lot of the wires were cut (drunk engine pulling is bad) so I doubt I can re-use it, although I still have the stock ecu and if I can't work the DOHC harness in I can get a second pushrod harness for 100$ or so.
Ideas? I'm not afraid to get my hands dirty, but informed ideas I don't have. Thanks for any help.
- Andrew
- Andrew
