3500 in 95 camaro?
  • 3500 in 95 camaro?
    Has anyone ever done for that Gen camaro or is it even doable. If so is there a how-to anywhere?
    Its doable.
    You'll have to C-notch the subframe and make custom mounts, put your RWD timing cover on the 3500, which requires some mods, then the trans bellhousing starter location issue.
    It's a fun swap. I did it in an '88.
