Not everyone will need one, but from time to time you will need to change belt routing and drive the pump from the other side of the belt which will require a pump that pumps water when turned backwards. I need this for a swap of a 3.1 aluminum head engine into a Fiero. The late model front timing cover uses a slightly different water pump than the older 2.8 engines did. I needed the new timing cover to fit the cast oil pan the 3.1 has on it. So what I needed is a pump that fits the new timing cover but turns the direction of the pump that fits the old timing cover.
My solution is this, there are probably other ways to get there however.
I got a new pump that fits the timing cover on my engine. I removed the cast impeller from the pump. You cannot pull them off with a puller, the case iron will just break on you. I drilled a small hole through the impeller next to the shaft taking care not to drill into the shaft any. I then used a die grinder to cut a slit in the impeller so I could crack it with a chisel. I supported the other side of the impeller on a concrete block and just a couple of whacks with a hammer split it clean, the impeller just slipped right off. You cannot just drive the impeller off the shaft because you will trash the bearings and seal doing that. Next I will get an older pump with the proper rotation impeller on it, drive out the shaft and machine out the metal shaft from inside the impeller to relieve the pressure before I attempt to pull it off. That part will get pictures later. Then just press the new one on the shaft and off we go. Pictures below of what to expect. The water seal is done with the sleeve you see in the picture so removing the impeller doesn't affect it at all. I would think this would work with other pumps as long as you can find an impeller that turns the right way. Larry
