3400/325 e30...project GMW!
  • #31
    We have eccentric trailing arm bushings installed and fully adjusted out to have flat contact patch while lowered, never thought about "preloading" them, we would have to install a camber correction (or raise subframe). We connect the rear sway bar, disconnect front and use soft springs in the rear. Best launch to date is 2.0 60' with 360whp/2100lbs. There's a video of the weight transfer we are able to get in the appropriate thread, look how much the wheels tuck lol...
    Either way, it's a long road course car. Got a few sponsors to give rebuilt parts at cost or employee discount due to the magazine coverage (was also in Oct issue of Performance BMW mag) and the car owner is getting his NASA license so it can become a time trials car. Don't think it will ever see drag racing again, but the 2002 will and it has e30 suspension
    • #32
      I never really got into drag racing but in that world it was my impression that any camber that wasn't 0 was bad camber. That seems perfect for a straight axle. Also while the unsprung weight may be less the rotating mass is greater due to the CV/U joints.
      On the road racing side dynamic camber change is very important. I wonder how much adjustment would be required to get go from 0 dynamic to -5.
      ~sam
      • #33
        few other things done. grabbed a spare 3500 upper intake manifold cut the neck and relocated the throttle body. intercooler i got supported and cold side pipe with blow off valve. next up engine accessories.
        [SIGPIC]
        12.268@117... 11's to come!
        • #34
          • #35
            What was the purpose of moving the TB?
            • #36
              moving it away from the belt and down lower in the engine bay. it also allowed a better angle for charge pipes lining up with a 90 degree coupler. look at some previous pictures of the other manifold, it comes straight out, thus more cutting of the hood lol.
              [SIGPIC]
              • #37
                I was thinking that was for hood clearance.
                After all, that's why BMW leaned all their engines over.
                What did you have to do to clear the brake booster? Are you running power brakes? Do you have any good shots of the booster/master cylinder area?
                Current:
                \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
                \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
                \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
                Gone, mostly forgotten:
                \'90 Pontiac 6000 SE AWD: slow but invisible
                • #38
                  no booster. im not sure if im going to go with a wilwood triple master cylinder pedal setup, or just a massive brakes booster delete plate.
                  [SIGPIC]
                  • #39
                    So true. There's very little room when measuring from subframe to hood, that's also the reason people add skid plates to lowered cars. Broken oil pans are commonplace lol.
                    Not sure how you are going to like that, the brakes are very heavy when you take out the boost assist - hope your braking foot is is heavy lol. Lee is an excellent guy to work with, though.
                    Have you looked into the remote brake systems at all? There's also a hydro-boost setup if you are retaining a power steering pump. We share a shop with Condor Speed Shop, if you are getting rid of the P/S they sell a nice piece for bypassing the fluid on the rack.
                    Keeping e30 rack? There's several nice upgrades that only require a spacer to keep the angle correct, or the firewall hole has to be clearanced.
                    • #40
                      That's pretty much what I wanted to know... Is the 60 degree narrow enough that you can use a hydroboost in the stock location, or do you need to go to manual brakes or get creative with the linkage.
                      LS1 swaps into E30's can get creative with the linkage... The left valve cover partially occludes the stock brake booster mounting hole, but the due to the size of the bellhousing, the engine has to sit far enough forward in the bay that there's room on the firewall for an offset linkage.
                      M60 (BMW V8 ) swaps into E30's need to get *REALLY* creative as the left cylinder head completely covers the hole for the stock brake booster mounting location, and the engine sits far enough back in the bay that there's no room in the bay for an offset linkage. Basically, the offset linkage has to be built *INSIDE* the firewall.
                      I would expect the 60 degree engine to leave a LOT more room for a booster than either of those two swaps.
                      So do you have pics of the stock brake booster location?
                      Thanks!
                      Current:
                      • #41
                        the engine is as low as it can go without modifying the oil pan (about 1/8'' or so). the upper intake sits lower now than it does in the picture, i ditched the spacers.
                        the car already has a power steering delete block on it that allows fluid flow but im opting for power. im not keepin it or the e30 rack, but im going with a 95 m3 rack, powered. as far as hydro boost i dont want to mess with it, im going with manual. i know what is required to make a proper system work, ive drove a 240 sx with the pedal/triple master cylinder setup and it feels like a solid pedal, and like it. rx7 brakes are going on the front, which arent a floating caliper.
                        [SIGPIC]
                        • #42
                          if the hydroboost was mounted with an angle pointing towards the ds fender, and headers/manifolds to clear there would be space. tight, but space.
                          (this was the first crossover design)
                          [SIGPIC]
                          • #43
                            I bet if this was installed in an E36, the entire engine would behind the front axle center line . . . hmmm
                            -=PJ
                            Strike Zero Garage
                            2006 SCR-SCCA Street Mod Champion
                            1988 Volvo 780
                            1993 BMW 318is: Gas Sipper
                            1993 BMW 325is => 350is: Track Rat
                            1994 BMW 530i + 5spd
                            1997 BMW 740i: Hwy Killah!!
                            1998 Honda VFR800FI: Gear Driven Cam Goodness
                            2000 Dodge Dakota: V8 + 5spd = Smokey Fun
                            2004 Pontiac GTO - RIP
                            2005 Cadillac CTS-V
                            "If not under warranty, live with it, or bend over and grab ankles."
                            • #44
                              new update, i got clutch components. out comes the mocked up engine, accessory brackets will be made, clutch install, then comes a custom driveshaft.
                              clutch is a stage 3 6 puck. disc from a svo turbo mustang, high clamp load pressure plate, s10 slave/fork/throwout bearing, flywheel is for a 3.1l cavalier.
                              [SIGPIC]
                              • #45
                                This thread is soo full of win.
