Hi,
I've a 1997 Chevrolet Lumina LTZ 3100 (with cracked block) + a new 1991-1995 3.4 DOHC engine (without manifolds), then I'll start an engine swap (obvious).
According previous searchs, I've built a Part List needed for this project:
- Upper intake plenum with 2 brackets, vacuum ports & connectors, EGR valve with EGR pipe.
- Lower intake manifold with fuel rail + fuel lines.
- Throttle body with bracket.
- 3.4 injectors.
- Vacuum lines with connectors.
- Heater pipes with heater hoses.
- Water outlet from manifold + water inlet to water pump.
- Engine wiring harness with connectors & fuse blocks.
- PCM with its box.
- Transmisson dipstick tube.
- Vacuum pipe transmission modulator to manifold.
- Belt tensioner + serpentine belt.
- Power steering pump reservoir + pulley + lines.
- Alternator bracket/support with shields.
- A/C compressor (4 ears V5 style) + lines.
- Complete exhaust manifold + heat shields (LH ex. manifold + RH ex. manifold + ex. crossover pipe).
- Motor mount supports & brackets (engine to frame, engine to transaxle, engine to radiator support).
- Flywheel & starter covers.
Any more?
Other ideas will be appreciated,
Thanks in advance,
Denis V.
- 3.4 injectors.
- PCM with its box.
Any more?
Thanks in advance,
Denis V.
