I'm in need of help with the wiring on my engine swap, a 1994 Camaro 3.4L/4L60E in a 1981 Chevette.
I'm in the process of modifying and merging the wiring harnesses from both vehicles.
I have stripped out all of the unnecessary wiring from the Camaro harness. ABS, SRS, smog pump, power steering, A/C, and cruise have all been removed.
The alternator and coil packs have both been relocated to opposite sides of the engine compartment compared to the Camaro.
I have the PCM mounted and wired up the coil packs, alternator, injectors, both O2 sensors, MAP, KS, IAT, TPS, CTS, OPSU, crank and cam sensors.
Here's the problem... a mystery plug!
It's a 2-pin plug with brown and black/white for wire colors.
Does anyone recognize this?
I believe it was on the driver's side on the Camaro.
Any help would be greatly appreciated.
Also, any links to information on merging wiring harnesses during an engine swap would be great.
I'm trying to figure out where exactly Camaro wiring should meet Chevette wiring.
Please forgive the lousy cell pics.
