Hi, I'm New to this forum and have been reading some of the threads.There are some awesome builds. I have a few questions for my own build. I have a 1951 willys jeep which I rock crawl with. Right now it has the original 4cyl engine which i converted to run on propane and made an adapter to run a t-18 for trans with 6.32-1 first gear. In need of a little more power (NOT ALOT) Just more than the 65-75HP i Have now. I have just been given a 1997 Chevy Lumina with a 3100 engine, trans is bad. My thoughts are to use a th350 using an adapter from Speedway motors. Motor mounts I can fab. I'm building a whole new chassis so i'm not concerned with exhaust or oil pan mods. When it comes to the computer side of the project I need help. Questions #1 my car has a computer controlled trans. and a anti- theft system can I just use a differant ECM or do I need to send it to someone to have it reprogrammed. also is there a wiring diagram available to modify my harness. Option #2 can I run a stand alone harness for the dis ignition if I decide not to use the fuel injection and convert to propane. Any help I can get would be appreciated. Excuse my ignorance on all this computer stuff.
Thanks
Thanks
