3400 heads
  • #16
    If we can put together a 3500 swap guide similar to the 3400 swap guide, I am all for it. I would suspect a lot of the 3400 guide could be used, and then add in and/or alter areas as required to make it 3500 specific. So yes, if you can help out (or maybe I should say I'll try to help YOU out), then let's get it rolling!
    • #17
      Right on let me know when you guys r all done. I don't know when I'm gonna get to do this but hopfully soon. Thanks!
      • #18
        Also what cars had the 3500 and should I be looking for the VVT or non VVT?
        • #19
          Non-VVT
          Started in 04-05 Malibu, and then in the new vans, such as the Uplander and similar models.
          • #20
            Is there anything that was between 2000 - 2003 with the 3500?
            • #21
              No, as the 3500 wasn't introduced until 2004.
              • #22
                I will start a new post in the engine swap section.
                Mike 60degree addict.
                • #23
                  Ok let me know when you do and what it's called or post a link to it. Thx.
                  • #24
                    3400 Head cast numbers
                    I have been searching for where the cylinder head cast numbers are on a 3400. I found some cast numbers listed here such as: 24507487 or 24507577. But, when I looked at my 2004 Grand Am, and another I found: 12580234 or 1258023.Click image for larger version
Name:	GA cast number.jpg
ID:	376400 Does this seem/look right?
                    • #25
                      Just found this from Engine Builder Guide TechSolutions Guide: General Motors.
                      Cylinder Head Replacement for 1996-2005 GM 3.4L VIN E Engines
                      "Any time you are replacing a cylinder head on 1996-2005 GM 3.4L VIN E engines the following information should be reviewed.
                      To date there have been two different rocker mounting bolts used to secure the non adjustable rockers to the cylinder head. While the cylinder heads are otherwise interchangeable, the rocker arms and bolts may not be. There is at least one cylinder head casting number that has been manufactured with both 8mm and 10mm rocker bolt holes. A list of casting numbers to assist in identifying which head is required.
                      Head Casting Number / Bolt Design / Rocker Arm Part Number
                      24507487, 12568234, 12580234 / 8mm / 12576628
                      24507487, 10218170 / 10mm / 24504436"
