Turbo Grand Prix 3500 swap
  • #46
    hmm.. now i know how to hook up that sensor to get a waveform off of it...
    and since there is a running 3500 car in my driveway i think i know what i'm going to do tonight.
    • #47
      I was having a hard time getting both signals since the 58x is so much faster but damn it's a clean square wave...
      this is 2 rotations of a 7x
      • #48
        AWESOME! How did you hook up to get that signal?
        • #49
          lots of work and potential incompatiblity...
          or you could... you know.... just run the 1227727 on either 8F or code59 and save a LOT of time and potentially money.
          Would still have to buy a trigger!
          • #50
            dave is cool enough to have a sillyscope.
            • #51
              Do you have one showing a full revolution of the LX9? It may help people to understand what a weird signal it uses.
              Damn... I still need to get a scope.
              MinusOne - 3100 - 4T60E
              '79 MGB - LZ9 - T5
              http://www.tcemotorsports.com
              • #52
                Not yet, i was running low on time when i got that one. I also need to pick up some floppy disks so i can save the waveform instead of taking a picture of it. I might have to run it at a higher RPM than 900 as well.
                If i can talk Abob into coming over to my house again this week i'll get some better captures, i could do a live feed from the scope over the net as well but that's almost too geeky.. even for me.
                • #53
                  After this thread, I had to dig out my Velleman handheld I bought several years ago when I was working on my standalone project on the Beretta. Not sure how many times I used it, but it still looks brand new, and even has the plastic film still on the screen! Too bad I don't have a 3500 to mess with.
                  • #54
                    I finished the wiring harness diagram for the megasquirt swap, this setup is using GMDIS with an external trigger:
                    Megasquirt = signal = TGP engine harness
                    20 tan/yellow = intake temp = C22 LT GRN
                    21 purple = coolant temp = C16 YEL
                    22 blue = tps signal = C15 DK BLUE
                    23 lght blue = 02 = A16
                    24 green = CPS = D13 PPL/WHT
                    25 gray = iac1 = A1 LT BLU/WHT
                    26 gray/red stripe = 5v ref = C12 GRY
                    27 white/blue strp = iac2 = A7 LT BLU/BLK
                    28 red/white stipe = 12v = D17/C7 ORN
                    29 green/red str = iac3 = A8 LT GRN/WHT
                    31 orange/black = iac4 = A2 LT GRN/BLK
                    32 gray/yellow = bank1 inj\ = D9 LT BLU (2 4 6)
                    33 gray/yellow = bank1 inj/
                    34 pink/black = bank2 inj\ = D3 LT GRN (1 3 5)
                    35 pink/black = bank2 inj/
                    36 yellow/black = ICM = C9 TAN/BLK
                    37 orange/white = fuelpump = D7 GRN/WHT
                    9 SENOR GOUND = C6 BLK/WHT
                    10 = C5 BLK
                    11 = C10 BLK
                    12 = D4 BLK/WHT
                    • #55
                      Question about the Transmission. What does it need from the ecm to run?
                      • #56
                        I found this documentation to controll the TCC with Megasquirt2 using the fast idle output to trip the solenoid.
                        For example, if you wanted to use the FIdle output as a TCC control, and the accel LED as an indicator that the TCC is active, you would set:
                        * FIdle (PM2):
                        o Port PM2, enabled
                        o variable = map < threshold = 75, hysteresis = 10,
                        o AND
                        o variable = coolant > threshold = 160, hysteresis = 10,
                        o Power-on value = 0
                        o Trigger value = 0
                        * Accel LED (PM4):
                        o Port PM4, enabled
                        o AND
                        o Trigger value = 1
                        Example: Torque Converter Clutch Control
                        Suppose you want to engage OD (overdrive) over 50 kPa MAP, and engage the LU (torque converter lock-up) clutch at 75 kPa MAP, provided temp is over 140 and RPM is over 2000. For a torque converter clutch control (TCC) using FIdle with 3 conditions (rpm > 1500, CLT > 160, map < 75), set:
                        PA0 - Knk Enable:
                        * rpm > 1500
                        * coolant > 160
                        and
                        PM2 - FIdle:
                        * map < 75
                        * port0 > 63
                        Then use the FIdle output to drive the TCC relay (if you have a relay board, you are all set). Not that you also need a 3/4 gear indicator switch and a brake switch in the external circuit:
                        EDIT: megamanual won't let me copy the image of the TTC Control Circuit so here's the link to the webpage, the image is about 3/4 the way down the page. http://www.megamanual.com/ms2/spare.htm
                        Is the brake switch already present on the harness or is that controlled by the TGP ecm?
                        If so, it's as simple as:
                        30 green/orange = TCC = B7 TAN/BLK
                        • #57
                          jon, i think you're making it much harder than it is...
                          if you take a look at the diagram, you'll see that the brake switch is a necessary part of TCC operation. whenever the brake is pressed, the circuit to apply the TCC is broken, so no more lockup.
                          and what is this about engaging overdrive? the 4T60 has a VERY minimal set of controls from the ECM, and if you're at a high enough MPH compared to where the TV cable is positioned, it will shift into 4th regardless of ECM intention.
                          • #58
                            Great, Does the trans need any input from the ecm to activate the tcc?
                            • #59
                              well, yeah, the TCC apply circuit.
                              apply 12V, TCC will lock.
                              remove it, or break the connection via the brake switch, TCC unlocks.
                              • #60
                                Today I married the megasquirt harness with the TGP harness. I also installed the ECT that came in today and painted the UIM/LIM TB and valve covers metallic silver. I'll post pics later.
