Heres the run down.
The body of my black car is shot but the engine and trans is the only thing that's in great shape on the vehicle. (92' GP)
I recently got a hold of another 92' GP with a blown 3.1L but has a good body and so the science project thus begins. The new GP has sat for an undetermined amount of time but everything appears sound.
I swapped the good 3.1/trans from the black car over to the green car, before the engine was pulled from the black car it ran smoothly, but now in its new home it wont even run it just cranks and cranks.
I pulled the fuel rail and sure enough all 6 injectors are not firing, so i started checking fuses, even swapped out the engine harness from the black car into the green one and still nothing. everything is properly grounded all fuses check out and everything.
Computer is operational.
fuel rail/lines are getting fuel
did the carb cleaner trick and got it to backfire.
What could i be missing?
