92' 3.1L swap
  • #16
    im wonderig if i should just run a new wire through there, becuase the only wire thats connected to that is a grey one and the battery terminal wire
    EDIT: I was able to get one injector to give off a little bit of gas but the other 5 are inoperable until a voltage was applied directly from the battery, but now im getting 12v across both injector wires on all 6 injectors
    1992 Pontiac Grand Prix SE
    94' DOHC/4T60-E swapped
    94' Cutlass Supreme dash swapped
