I'm having some drivetrain alignment issues that are driving me nuts. Car is a 94 Beretta that is now a 3500 5 speed. Originally was a 3100 auto. I am using the new 94-96 style mount setup.
I have cut and rewelded the top mount 1" back. I have drilled a new hole 1" forward for the dogbone mount. Mounts are welded in the right spot on the transmission side. I have a FFP dogbone, poly insert in the upper, and I made my own 94a poly transmission mount inserts. (I have the 2 circular trans mounts). In other words, my drivetrain does NOT move.
Looking from the side of the car into the inner fender with the wheel off, where the axle comes out of the transmission is not directly in line with the wheel hub. It is the same situation on both sides. Where the axle comes out of the transmission looks at be at least 1/2" or more offset towards the front of the car. I believe the transmission output should be in line with your wheel hub.
This is hard to explain, so I drew a quick picture. It is from the passenger side view, with the axle removed.
Now heres the thing, I decided to check my daily driver, also a 94 beretta, but still a 3100 auto. Looking from the same angle, the transmission output is almost directly in line with the axle hub, as it should be. In other words, with the wheels pointing straight the axle is nearly straight (horizontally) from where it comes out of the transmission, to where it goes into the axle hub.
Now here are my questions. Keep in mind that my car is an L body with the newer 94+ 3x00 mount setup.
1. We all know that in the older cars (92-93), there was a 1" difference in upper mount orientation in an auto vs manual car, remedied by two different "T" pieces. However, with the 94+ mount setup, how can we know for sure that it is exactly 1" still for the upper mount relocation in an auto vs manual car? Since there was never a 94+ 3x00 manual car, I believe this to be an assumption made by someone.
2. Is it okay for the axle output to be horizontally offset from the axle hub like my car is, as long as both sides are the same? In other words, as long as the drivetrain isn't twisted, is it hard on the axles? Has anyone else noticed this on their cars with the same setup as me? If you think about it, the transmission output will be offset relative to the hub in a vertical sense, depending on the ride height of the car. Or is there a tolerance for this?
3. I have now found that there are 2 different part numbers for the lower dogbone in the 92-93 cars, depending if it was auto or manual. Does anyone know the difference between these two dogbones?
