3500 into a 99 GA GT
  • 3500 into a 99 GA GT
    ive been reading the info on here about swapping a 3500 into the grand am. mine has the 3400. from what ive read it sounds like the motor mounts are not a problem and it bolts to the stock transmission. i will need the external crank trigger from the WOT store and i can use the top half of the intake, fuel rails, fuel injectors, and ignition off of the 3400.... is this correct so far ? what cars should i be looking for to get a 3500 engine out of ? thanks for any help and info guys.
    IMO, you could do a top swap. The LA1 and LX9 can be interchangeable. Aside from some forged parts, and the LX9's VVT, you'll get a nice gain from just a top swap. I plan on doing it myself once the funds come in.
    -Chris-
    03 Black GAGT Sedan
    MODS:
    MP Racing CAI / Magnaflow High Flow Catalytic Converter / Flowmaster 80 series w/glasspack resonator
    Front STB / MSD Ignition: 8.5mm wires & blaster coils / SOME BIG GODDAMNED MUDFLAPS
    And some other stuff to make it look pretty.
      You do know the swap he's asking about involves the non-VVT 3500.
      Your local OBDII moderator
      2000 Grand Am GT w/ WOT parts
        Oh. And now I know.
        -Chris-
        03 Black GAGT Sedan
        MODS:
          Oh. And now I know.
          OP: You should be able to find what you need in a 04-06 Malibu, Terreza (sp) or G6.
            By using the UIM from the 3400 you are really cutting into the airflow of the 3500 which is its biggest PLUS.
            I recommend using the LX9 Intake, but, you will need a TB and TB adapter.
            As of April 2
            Engine: 2006 SV6 3500 LX9
            Trans: 2002 Getrag F23 5speed
            Injectors: #36 GTPs
            TB: 65mm TCE
            Maf: 1999 3400 Montana.
            Beverages: Ice Cold CANADIAN.
              Stock for stock, the LX9 is superior, but ported, you'll get more airflow with the LA1's UIM.
              -Chris-
              03 Black GAGT Sedan
              MODS:
                You have that backwards.
                  D'oh. Today isn't my day. lol
                  -Chris-
                  03 Black GAGT Sedan
                  MODS:
                    thanks for all the info guys. if all i need to make the 3500 work is that trigger and a TB adapter that does sound like a very easy swap. did the G6 engines have the forged cranks in them ?
                      You have to check because I guess some of the 3500s did not get them. I'm not sure if it is car specific, but you have to check the snout of the crank for a certain casting number or something like that.
                      EDIT: Have a looksy in this thread (post #3 by Forced, he says what number on the snout means its a forged steel crank):
                      Steel has a "7484" and "5041600" stamp on the snout.
                        i feel like im missing something..... all i need to swap in and overhead cam 3.5 in place of my pushrod 3.4 is that trigger and a throttle body adapter ?? my computer will work but just need a little tuning ? sounds too good to be true
                          What engine are you talking about? The 3500 is a pushrod 60* V6 similar to your 3400. It is not overhead cam. The 3.5 DOHC V6 is a completely different motor.
                          -Matt
                            not to bring up an old thread,
                            but if you are still looking at doing this swap there are a few other things you need to bring over from the old engine. Like the two crank sensors, fuel rail and a cable driven throttle. Its not that hard to swap the engine just need time and all the right parts.
                            The two engines are basically built the same way and gm just updated a bunch of things on the LX9. You just gotta make sure you get an LX9 3500 cuz at some point (2008ish) they started using a VVT 3500 that is completely different and wont work.
