Hello,
I've been reading all the posts I can find here regarding 3500 swaps and have yet to be able to figure out a few things so I thought I'd break down and ask.
I have a '98 Malibu with the 3100 and auto trans. The motor needs to be rebuilt or replaced. I'd like to just install a low mileage 3500. What I can't find out is;
1. Engine Mounts - Will it bolt in with minimal custom work?
2. Auto Trans - I can rebuild mine or buy another low mileage one from linders. If I buy a newer one, will it bolt up with minimal custom work? Gearing - lost here, unless a newer trans has the exact same gearing as mine I don't know what would be "compatible" for lack of a better term.
I'm not looking for a race car, just a reliable daily driver. The car is in great shape and just needs an engine. The trans is only being replaced or rebuilt since it wouldn't make sense not while everything is out of the engine bay. I have limited time I'm looking for easy, very minimal custom fab work, get it back on the road quickly solutions. What looks easiest on paper is getting a 3500 and AT from a newer malibu.
Thanks in advance.
Thanks in advance.
....or, is there room between the block and the mount to simply bolt a drilled/slotted flat plate to the mount?
