Bought a 98 Malibu that broke the cam for pretty decent price. Got a 95 3100 sfi engine and trans for $125 garanteed. Its out of a Skylark if that makes any difference. Just want somebody to go over what i've done so far and point out anything else I may have missed. Long time lurker, finally decided to sign up. Been on CZ28 and other f-body websites for years.
Changing upper intake/egr, fuel rail and probably injectors, front accy brackets, idler pullies, using 98 starter, using 98 coolant tube assembly, got a heater hose fitting for the threaded intake hole, leaving exhaust manifolds on the 95 motor if I can, The front was the same part number from what I could tell, but the back was different, my crossover pipe goes right on the 95, its pipe was missing. I know I need to swap O2 sensor on the rear manifold(IF I can use the 95 manifold)
As far as I can tell the 95 has one coolant sensor on the head that wont be used, and i have to change the other one. Knock sensor, is the hole the same size for both engines? Im also using the icm and coils from the 98, even tho I think they are identical. Looks like my a/c comp will bolt up too. Engine will be out tomorrow and the part swapping will hopefully begin. just wanted to know if I missed anything so I dont have to make the 15 mile drive to the parts store in the middle of it. Also already bought most of the smaller problematic hoses.
Also planning to change the lower intake gaskets soon to prevent the leak, If I had the extra $$ right now Id just do it now while its all right there but I dont. Hope to do a top swap when I do that as well. Have been reading everything I can find on this site about the two engines but most of what I've seen is going the other way lol.
