Originally posted by 94GPGTP
View Post
95 GTP 5 Spd Swap and OBD 2 w/ 96/97 Engine..
Originally posted by robertisaar View Postyou can ignore J2, it applies to 96 GPs and since you have a 96 lumina harness...
E1 on the 95 and F1 on the 96 are for the same function. switch the pin and its done.
not sure if the others need to be wired indivually yet, i'll check to see if they are wired somewhere else...
The J2P sounds like it has to do with the Diagonisc port? Thats is what i think though..
Also i know that that has to be rewired.. do you happen to know how that goes?Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
Originally posted by robertisaar View Postit looks like you'll need to play with the C200 as well...
Not Familer with that.. wheres it located? could you send me wiring diagrams again and ill print them out and read upRobert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by pocket-rocket View PostThat might be your best bet. When was the last time the belt was changed? It's got to come off anyways if you change that gasket. Oh, and take that Fram off of there lol.
Give me something to believe why Fram is no good... LOLRobert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by 94GPGTP View PostGive me something to believe why Fram is no good... LOL
1. My personal experience.
2. Even the Ranger guys know to stay clear of them
I was driving down the road and noticed some smoke, engine started sound like crap, shut her down and towed back tot he house. No oil in the engine. Added oil, started it up and it looked like an oil bomb went off under the hood and all the oil was on the ground. I had previously ran the...
To quote a couple of the guys on there:
i would filter my oil through a roll of toilet paper before i used a fram.it's not a leak that is the problem the SOB'S blow holes like it's been shot with a 357 mag.. $60,000 motor replacment in a 385 excavator over a fram filiter...IIRC, Totalled had 3 Fram filters blow up on him...Back in the day, when I was working in the quick lube at my dealer, we would crush oil filters for recycling. After hearing the crusher turn fram (and other cheap filters) to a
1/4" tall hockey puck without a grunt or groan, I would never use one of them. The same size motorcraft it would bog down the crusher a little. You can definately tell who uses the thicker skin.Last edited by pocket-rocket; 10-14-2009, 11:02 PM.-60v6's 2nd Jon M.
Originally posted by robertisaar View Postmore pics, should help determine where wires are going to/coming from.
this fixes what is missing from the 96 harness.... i think.
you might have to trace them from here... i can't seem to find much more info on them....
When i click on the thumbnails seems that half the picture is missing.. is showing a small portion not the whole page..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by robertisaar View Postthat was actually on purpose, i just left the important parts in it.Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
i can find where the wires end up, but not how they pass through.... as in they don't pass through the C100, but i can't find which one they do pass through. which is why i found where they end up, what pin of the connector and some idea of where they should end... everything thats missing from the 96 C100 connector should be listed in that last set of pics. i haven't worked on the 95 due to an information overload. its tough looking through all of the diagrams and making sense of it...
i know the harness for the cruise and wipers and stuff pass through the firewall next to the booster and there is no plug just straight wired through..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
you were saying something about the c200.. so diagrams on that for the 95 and 96.. i am not sure on anything else.. once i find out ill let you know.. thaanks much though for all the help and info so far..
i did find a spreadsheet from a previous swap done but it looks to be unfinished and not certain.. found here http://60degreev6.com/forum/f99/obdii-swap-t36113Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
