so i could in theory(sp) buy a 4L60 from a LS1 car remove the bell housing and just buy a bell housing fror a 2.2 s-10? well jeese this is a bit easier then a i thought.
the controler will be a snag though i bet they are pricey
i found a thm700 for a 2.5L 4cyl S-10 any one know what bolt pattern that has? i can not see to find mutch info on it i think it is the iron duke like what is also in the F-bodies and fiero
ya the strater is the mistory. i gues i could go to the yard and look at it and then post my findings may help peaple wanting to put a gen III in a RWD vehicle
/me raises hand!
I want to put a 3500 in mine, and am trying to make my turbo setup so it will even swap over
Are you sure it's not easier to notch the bell housing in the RWD auto? I'll be mounting a 4t60 (non-e) to the motor in my garage in the next few days, so I'll be taking a closer llok at it.
I don't think you have to notch the auto trans. It looked like the starter would work on the left or right with the th200 (3 speed) in my 83 firebird. just needed to make/ modify the torque converter cover for the oppiste side. I would look in to it more but my trans is too deep in my storage unit right now.
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
