im new to the 60 degree ownership expirience and i want to put 3.4 top end on my 3100 i found a guy with a rwd 3.4 in a 95 camaro and wanted to put the top end on mine is there a difference? thanks for the help
fwd vs rwd
First, welcome.
Second, you don't want, nor can you even, do that. The 3.4 Camaro intake is for iron heads and is therefore incompatible with the aluminum heads on your 3100. Second, the 3.4 intake flows WAY WORSE that the 3100 intake. So even if you could do it, it would be a downgrade in performance.-Brad-
what year is your 3100? if its 2001 or before you could always swap to 2001+ heads or 3400 heads/topend in general, but honestly 3100 heads/intake are far from poor. you could just put on some headers, bigger tb & cai/ram air, port matching/minor porting, and a crank scraper-that should give you some nice gains
