im helping a friend do a top end swap on his 92 3.1 were putting on the 97 3100 top end , heads, intake the whole high flow top end but we need headers and cant find any can anyone please help us, dose any one know where to get the D port flanges?
headers?
DIY pretty much...
Unless you modify SS headers (cut the rears to angle down right)sigpicNew 2010 project (click image)
for a Camaro?
any headers for the 2.8/3.1 will work fine. With a 1 5/8" primary you shouldn't have any overlap of the D.. You will have to oval out the mounting holes since the aluminum heads have a slightly wider vertical spacing.
If you really want the D port flanges, then i'd PM "Betterthanyou", he sells them. Then i'd use Camaro headers and just cut off the old flanges and weld the new ones on. Shouldn't be too hard if you have aces to a plasma cutter.
BTW, the '97 3100 stuff is ok but the '00+ stuff is better. At least try to get a 00+ LIM and UIM.. much better flow.
