i have a 01' prix wit 3100sfi i was wondering if i could change my lower and upper intake without having to change anything else or what upgrades would you guyz recommened while im there?
You still have a 52mm TB so going with a 56mm would be a cheap and effective upgrade. Porting and going with a larger billet throttle body would work well too. It depends on your budget and goals.
Just get the TB adapter and adapt the vacuum lines. Use your old MAP sensor with vacuum lines, or splice in the 3500 MAP like I did.
Tuning is always good but for such a small mod not needed unless you are serious and plan on more radical stuff later. Tuning even on a stock engine can get you power.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
