Alright I've got a 95 beretta Z26, when I picked it up the intake gaskets were shot (go figure). There was quite a bit of tapping coming from the top end. So instead of just changing the gaskets I put 01 or 02 3400 heads on. I used stock pushrods, but brand new ones. The heads had 40k miles on them and where perfect. I used stock 3100 head and intake gaskets. The car runs about the same as it did before. Heres my problem, still makes a ton of noise up top, is it possible for water and oil to mix long enough to wear out a cam and nothing else? Also I plan on just rebuilding it anyway any ideas or suggestions for building a hi-perf N/A engine?
3100 with 3400 heads
