I have a 95 3.4 that I am just about to purchase all of my internals for. I plan on using a set of aluminum heads from a 02 Grand Am. I know I need to use dished pistons but there are several dishes available. Which dish do I need? I would like to keep my compression in the 9's so I can run pump gas...
Also, does anyone have an opinion on Mahle pistons?
Just to clarify a couple of points, I saw a thread (elsewhere) indicating that you must use the same dish as the motor the heads came from. I was TOLD my heads came from a 2002 Grand Am but I can't prove that. I have also seen a post that indicates there was a flat tappet motor that used the Gen II aluminum heads so custom push rods are not necessary for me to complete my swap...
