scored on a clean 86 blazer, 4x4, cruise, AC, 5 spd trans, 90K on the odo, has a broken crank but it was only $400. I have a good running 2.8 from a previous swap. There I am, engine hanging on the cherry picker ready to come out but its hanging up on something,WTF oil pan hitting the front axle, trans input shaft still in the pressure plate WTF. break out the chiltons ( a liitle late) OOOHHHH you have to pull the trans befor you can pull the motor!!!!!! Was able to unbolt the pressure plate and get the motor out but still WTF!!!! Just needed to gripe, thanks for listening
