Ok, so I decided to do an engine swap for my buddy. I have a '93 3.1 out of a lumina, and he has a '86 celebrity.
He had told me that it ws TBI, serpintine belt, so it wasnt as big of a deal, but I come to find out that its all v-belt with a good ole 2bbl carb.
So, I have the choice of either making the 3.1 carbed, or converting the celeb to MPFI.
The problem, is I dont know If I can use the intake, front cover, water pump, etc from the 2.8 carbed to fit the 3.1
The other factor, is I could make it 3.1L MPFI, BUT, I would have to swap the PCM and harness, and I dont know exactly how difficult it would be to splice a PCM into this vehicle. On top of that, they desperatly want to save the AC (it still works), which cannot be mounted to a 3.1, and does not have a serp belt pulley.
SO, what I would really like for you all to tell me, is that I can use the 3.1 block and swap everything onto it from the ancient 2.8, including the intake, front cover, water pump, and mounts.
Thanks for your input.
