First, yes I saw that someone recently bumped up a thread about swapping a 3400 on to a 2.8, and yes I went through all 14 pages of it. Seeing as that didn't really get anywhere I figured I'd start my own thread.
What I have:
I currently have an 88 GP 2.8/282 combo with tgp parts on it. I ran about 5-6000 mile on that this summer, and I figured it was time for more. Seeing as I don't drive the GP in the winter, I figured it would be a good time to add some parts.
I also just bought a 98 3400 with a ton of miles on it, ~182k if i recall. Full of nasty emulsified oil. Guess the previous owner had some good LIM gaskets on it....NOT
I've torn it down and pulled the heads off so far.
I plan on running LS6 springs with the Comp retainers and locks.
What I need:
1.) Right now, I'm planning on the GMPP Crane 260. $160 w/lifters is tough to beat. Can anyone suggest a better turbo cam for a similar price???
2.) What should I check the heads for? I was planning on checking valve guides and a 3 angle valve job to clean up, and probably just have the mating surface cleaned up too, not milled or anything, just cleaned up. Is this logical?
3.) Can anyone recommend a decent machine shop in NE ohio to do the head work?
4.) 3100 GP throttle cable
5.) Water Neck from thermostat housing in LIM, JY swiped mine.
6.) Coolant bypass pipe, goes to TB and heater core, JY sawzall'ed mine. I'm not 100% on this one yet, seeing as i have to T into it for my turbo coolant return. I've heard that i need a new one, and the old one can't be carried over.
7.) A good excuse to tell my girlfriend why I NEED to do this.
I know I don't have everything covered right now, but I just want to make sure the ball is rolling in the right direction. Springs, retainers, locks etc can be ordered or picked up, I work close enough to Summit Racing that the LS6 stuff can be gotten in a day. Just want to make sure when I take the heads in I've thought of anything.
Thanks for your help in advance. I'll post pics eventually if anyone cares.
Jon
What I have:
What I need:
Jon
