I've read quite a few threads with people talking about it but they never seem to show completion. Anyone got one rollin?
Who has completed a successful 3.6 swap?
There was some guy with a sand rail that had one on here. Didn't get much info out of him. I think he had pics, I can't remember.sigpicNew 2010 project (click image)
The engine is a little bulky, more rare than the pushrod motors and has a lot more complex engine control system.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
It's all aluminum externally so it certainly shouldn't be heavier than a 3.4 DOHC. I don't remember which thread but I do recall posting the weight. You have to decide what to do about the VVT which is a bit more complicated than the cam in block VVT motors though I'm sure you could find a way to fix them into an optimal position. Depends on what your plans are. All of the manual flywheels for it are dual mass I believe and your sources are likely the Saab 2.8L DOHC motors and the Cadillac CTS, in which case you would also have to use a Saab manual trans as a result or have a custom flywheel made.
Mine is in process:
This is the manual transmission from a CTS being checked for fit in a Studebaker.
If someone has a link for overall 3.6L dimensions, it would be greatly appreciated.sigpic
1963 Studebaker Avanti: C4 Corvette narrowed front/rear suspension, C5 13" calipers/rotors adapted to C4, Viper differential with Intrax 3.54 ratio (the snake has been charmed!), coil overs, stainless tubular frame, stainless chambered side exhaust.
Here is a link to a slide show on the frame and car. Slide Show
Here is a link to the magazine article written on it: Magazine Article
