Hey guys i'm new on here, i was looking for a little intel on what i need to get together to do a 3400 swap into my 89 corsica Lt has the poor boy 2.8 in it. thanks
well to get you started you need a 3400 motor and a set of motor mounts out of a newer corsica with a 3100
you will probly need the throttle cable off of that 3100 car as well i think your ecu and harness can be kept and there will be some other stuff that post up i am sure but that should get you started
ok that works for a start thanks, i have a 96 corsica parts car since the engine blew so i rape it for the mounts, ecu wise would it just be easier to get my 89 burned for the 3400 maps, my cars a 5 speed. well thanks that helps alot.
Lucky man. I wish my Corsi was a 5 speed but I'll have to make do with my 3t40 auto until I can find a donor car. Since you already have the other car for parts you've got it made. Ben at WOT-TECH has a 3400 chip I believe, but if not there are a lot of guys who could burn you one. If you plan on modding the engine at all look through the WOT-TECH store they specialize in performance parts for our engines. I have some of Ben's products on and in my engine, very good stuff.
Yea so i have all the mounts needed i'll pull them tomorrow, a guy i know has a 3400 with 60k miles on it out of a 99 venture so i get that from hom, only was askin 550 for the motor. yea i was just on wot-tech looking at all thier stuff for the 3400 engines, Ben referred me here when i emailed him about the swap. I'll probably get a tune from him and the pnp intake manies, if i'm correct i think the chevy van intakes had some flow problems or something with the way the internals of the intake were setup. and the 89 ecu tune chip. is there anything else i should be lookin into? what about the newer mass sensors?
