3800 to a 3x00 (01 GP GT)
  • 3800 to a 3x00 (01 GP GT)
    yup just wounder what all would need to be switched i would ask on ClubGP but they would say i am an idiot and not give any usefull answers.
    things i think will need switching
    upper engine mounts
    exhuast Headers/Manifolds
    wireing harness?
    PCM tune
    fuel lines
    if i missed any thing let me know i am getting a compleat 3400 with all the accesorys (including A/C compresser)
    92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
    Hellz yeah, 'bout time somebody smartened up :P
    Dave justmentioned the 3500 is 120lbs lighter than the L67 woot.
    Are you staying N/A?
      i'm going N/A currently S/C'ed my gole is to get the same out put as i have now with out a power adder and shut some peaple up on ClubGP so far i have figured i can do this cheaper then my previuse set up. just working on what cam to use and pesky details before i start taking the car apart.... agin
      the engine will be a 3400 block with 3.4 pistons and a 3500 top end with a 3100 UIM to freak peaple out at the track
        you'll lose power with the 3100 UIM.. i'd just stick a 3500 one on there.. nobody knows what it's from so you'll be safe.. lol
        Sounds like a good combo, toss a cam in the mix.. somewhere around .510 lift and 270 advertised on a 110 LSA and grab a set of headers.
          Not a ton of power if you consider the "wow" factor, lol.
          With a nice cam, you should shut a lot of people up.
          Here's my specs (remember I have 1.6 rockers with the 3500 top end, so the #'s are a little skewed)...
          Dave will probably share his, his bump stick is a little bigger
          Use the 3x00 gaskets, and don't forget valve springs. The yellow springs are good with my cam, Dave's require the Comp springs IIRC
          EDIT: Please don't tell anybody at FT until it's complete. This will be good
            that is the plan it will not happen over night eather with school and stuff but i will get the engine soon part it out and go from there
            witch is why i am figurring what i need to swap first
            you still selling the 3500 Top end stuff ported?
              don't go with this much duration.. espicially if you enjoy driving the car.
                Just getting in on this one to help keep a watch on it. I LOVE the idea behind this and can't wait to see how it goes.
                Taylor
                1998 Lincoln Mark VIII
                  ok after some serching this is what i found
                  L36 Powertrain Control Module (Tune)
                  L36 High-Pressure Power Steering Line
                  L36 Stock or Custom/Aftermarket 97+ Style Exhaust Downpipe
                  L36 Coolant Hoses (New)
                  Upper and Lower Radiator Hoses
                  Heater core lines
                  Belts
                  now i know it is for the wrong engine but the revers should work (i.e. get stuff for a grand prix se with a 3100) this is actualy good it means i do not need new fuel lines (mine are new with 1,000 miles on them)
                  i will add more as i find it
                  some wiring is also need but thats cool i like wiring stuff up
                    I'm going to put a 3500 UIM on my 3400 and just paint 3100 on it . No1 will know the difference
                      ok i will need upper engine mounts (dog bones and the part that bolts to the radiator core support), and a fuel line repair kit (the 3800 fuel lines are to long)
                      so far it dose not seem to be to bad most of this i can get from a junk yard
                        bout time! the l67 is a boat anchor for sure. when u put pistons in it, go to summit and pick up a set of hyper pistons. theyre like 15-20 bux each. stronger and u could go boost or some juice if u decide to.. lets see this get done!
                        [SIGPIC]
                        12.268@117... 11's to come!
                          was talking to some one who put a 3800 in his 02 GP SE and found out the upper dog bones do not need to be replaced they look diffrent but the are close enugh.
                          now to get money magicly and get the 3400 (was going to sell engine and parts in car before hand but i need it to cart my azz to school )
                            Just throwing this out there because I didn't see it said anywhere else in this thread, but if you have a 3800 90* V6 then it has a different transmission bolt pattern than a 60* V6. I'm pretty sure that means you need a transmission to go with that new 60* motor.
                            If you are going that far and getting a new wiring harness I would look for a computer out of a similar vehicle to your own that was made for the new engine/trans setup you will be running. With all of those things needed it would probably be cheaper to have a parts car around than to haul over to the junkyard every time you need a little piece here and there.
                              The 3800 has the metric bell housing pattern, jut like the 60 degree does
