I need to cut into the unibody for added clearance.. I need to cut about this much out here:
I will be cutting the lower 90* bend.
I want to make sure it doesnt bent out of shape while cut. Im going to weld a couple days after the cut. I know the car cant be on the ground because the springs will push up on the unibody. Im thinking about putting it on stands that will be placed on the subframe. The subframe should hold it together as long as the strut towers dont have any pressure.
Im probably just being paranoid but I DO NOT want to screw this up.
Any advice?
Any advice?
