Parts are starting to trickle in, so this is my build thread. I'm looking for a solid 4x4 power plant for my 1990 Isuzu Trooper LS. I would like to have the option of supercharging it with 5-7psi boost, but not right now. Looking for advice on what bits to get, best practices, etc. I'd like to clear 200hp N/A.
I have now:
'93-'95 F-Body Short Block
'98 3400 Heads (stock valves/springs), LIM, UIM
'00+ 3400 UIM, EGR.
56mm Throttle Body
'02 3100 Wiring Harness
I need... everything else...
Fuel Rail
Injectors (what flow?)
Pistons (stock?)
Cam & Lifters (Crane H260-2)
Pushrods ('91 3.1L MPFI)
Rockers/Studs (pre-'03 3400)
Nuts and bolts
Etc
If you can think of something I need, post it. If you have something you want to sell me, post or PM.
Think I'll have the LIM/UIM worked over by WOT.
I have now:
'00+ 3400 UIM, EGR.
56mm Throttle Body
Fuel Rail
Pistons (stock?)
Nuts and bolts
Etc
