Hi everyone, first post,my goal for this car is a 3.4 with carb and hei dist.My ? for u guys is can i get a intake mani for this engine and what is the smallist auto trany that will bolt up to it? I know a t50 will work but i would really like an auto. Thanks in advance for any info guys. Scott
3.4 into MG Midget
The 3.4 will take the same trans. as a 2.8 rwd. There's an Edelbrock intake available for two or four bbl carbs but exspenive if bought new, Offenhauser made a 4bbl intake but no longer in production, could find used.Also there is a Weber downdraft 2 bbl setup that can be adapted to some stock manifolds.
the s-10 and 3rd gen F-bodies use a 700r4 trans, pretty much 1982 and newer but try to get the newest one that you can. Try to get 88-to the early 90's, they are the strongest ones without having to deal with a the elecrtonics.68 El camino 454 speed muncie 3.90 posi 12 bolt,
80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
60 Impala 2 door hardtop L79-327 T56 4.11 posi.
83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
91 Z34 now has a hm284. and belly pan in the works
Yea I would use the 700 R4 too. It is very strong, common and cheep. The the 200 4R does have a nicer gear ratio setup for lighter vehicles but I bet you will pay more for it and to get one with a 60 degree pattern may be a challenge. I cannot think of any application that will fit a 60 degree v6.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
i also say go with a 700r4. the small v6 units arent as strong as the larger v8 units, but all the v8 guts drop right into it. they are a 4 speed overdrive tranny with lockup, so you will be able to cruise and get good fuel mialage as well as have very good performance.
a 200-4r would be harder to find, basicly would have to find one from an early to mid 80s g-body with a 3.8l v6. another option would be a th200c, wich is a 3 speed with lockup. its a bit smaller than a 700r4, but would be hard to find.
But how would you bolt it to the 660? All the TH200-4R's used a dual pattern bellhousing which fit BOP and Chevy bolt patterns.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
the 3800 have the 60 degree bellhousing bolt patern but the 3.8l still have the B.O.P. bolt patern. they didn't make a 200-4R with a 60 degree bellhousing. your really limited to 700-R4, 4L60, and 4L60E (which are the same thing with refinement differences in them) unless you want to cut off the bellhousing and go to J.W. performance and shell out a load of cash for a custom SFI approved bellhousing that bolts to the pump68 El camino 454 speed muncie 3.90 posi 12 bolt,
