I worked on some wiring the past few days. I have a lot of it hooked up but I still have plenty of questions. One of my biggest questions is which wire is used for VATS? In my haynes manual it says it is a dark blue wire but it does not tell the pin location. Anyone know? Also there is a sensor that is not currently on the engine. I have a picture of it but my computer is not cooperating right now. It has a two prong electrical connection and two ports for vacuum lines, I am guessing it is some sort of selinoid but I do not know where it goes and what should plug into it.
With the fuel pump wiring I have soldered the newer plug on, and I have soldered in the hot wire from the relay, but I still need to wire the rest of the relay. Is there a wire from the ecm that I should be running to the relay or should I just find a switched source some where else? That's it for now. Thanks for any help.
