I will soon be swaping a 3.4 into my 85 XJ that has a carbed 2.8.  For the swap I am going to stay with the carb, and I have a few questions so far.  I know I will need to install an electric fuel pump, which pumps are recomended?  I know I am supposed to get a low pressure pump for the carb.  What about a fuel pressure regulator, do I need one, if so are there any that are prefered?
I am also planing on changing the clutch while I have the engine out. I sould be replacing the clutch with a 2.8 clutch and not a 3.4 clutch from a 93-95 camaro right? The most power it will ever need to hold is just from what ever power gains I can get from bolt on's.
I know the rear main seals are known for going on the 2.8 so I am going to replace the rear main seal on the 3.4 before I put it in. Are there other gaskets or seals that should be changed when doing the swap (I'm not rebuilding the motor)?
I also have a cam that I picked up off of ebay (I'll post specs later), but I have never replaced a cam before, but I have done engine swaps, I have just never changed major internal parts before. How easy is this when you have the timing cover off?
Are there any other worth while mods that will not break the bank that I can do while the engine is out of the Jeep? Thanks for any advice.
