Originally posted by ssterlingb
View Post
I am begining to wonder if I have a VATS problem too. Even if the fuel pressure is a few pounds low the engine should still run in my mind...possibly run lean or sputter up top, but I think it would start. I am talking to the people I bought my VATS bypass from, and I ran some tests on it tonight, it looks like the siginal possibly is not strong enough. The guy told me it should be testing at ~2-2.5 volts with the ignition switched on and when I checked it today my meter was only showing 1V when the ignition was switched on...I am starting to wonder if I have a faulty vats bypass. I sent in a picture of my testing procedure with the read out to the company so hopefully they will get a new one in the mail to me asap.
One way I could check my fuel pressure (see if the computer is telling to fuel pump to send fuel/VATS) is to leave the pressure tester hooked up while I am cranking the jeep. I am guessing if it fires up at 40 psi if the VATS system is not bypassed properly the fuel pressure should drop to 0 quickly. Make since?
Also I have a few other questions. Is the check engine light circut critical to the engine running? I don't have that hooked up now, but I bought a 194 bulb socket with a two wire connection tonight, and was going to hook that up for my CEL. Does this circut have anything to do with the engine running?
My other question has to do with the pink/white wires coming off the crank and cam sensor. According to the diagram they tie into pink C3 which is the ignition control line. I don't know if it is a typo or something but if you trace those wires back they end up at C18 injector control #1 and they never tie into C3...does anyone else see what I am talking about? Whats the deal with that?
**I'm going to ask a question in the general forum about the cam...I don't think that would be causing a problem. I just want to know if anything special needs to be done to run a cam in the 3.4 with out a cam sensor lobe (I know it is supposed to run MPFI without it, but I am wondering about any other problems).
