The ICM runs the ignition coils, so it should be wired between the coils and the PCM
3.4 swap into 1985 Jeep Cherokee questions?
Looking at the diagram, there are three connectors on the ICM and the coils wire directly to it. I think it would have to be located on the engine by the coils.
1st connector is power: two wires as described before.
2nd connector is twisted wire to crankshaft position sensor.
3rd connector is to the PCM.
Originally posted by ssterlingb View PostLooking at the diagram, there are three connectors on the ICM and the coils wire directly to it. I think it would have to be located on the engine by the coils.
I'm not sure where that ground wire is. I suck at reading the wiring schmatics. I see the wires going to the cam position sensor, and I see the pink "T" into the ignition wire on the ecm which I already have hooked to the hot ignition source on the jeep. When i turn the ignition to the on position the wire that I tied into the pink wire going to the cam position sensor is getting hot to the touch quickly and it starts smoking in a few seconds. I felt all of the other wires attached to the ignition wire where it is hooked and all of the other wires are cool to the touch. What would cause this wire to start smoking? I now have a fire estinguisher out in the garage
It is VERY possible that all six injectors are clogged. That happened to me. Noid lights are like $8, so it's a cheap test.'98 Volvo V90 - Ford 5.0 swap in progress
The wire would get hot and start smoking if it was a direct connection to ground.-Brad-
Although not for your vehicle or ECM, the main connections should be similar (the ECM pin numbers are probably the difference).
Maybe that will help.-Brad-
Originally posted by ssterlingb View PostThe 1st connector on the ICM is two wires:
1st wire is just shown as a jumper wire to the Pink 239 wire going from the 10 amp fuse #11 in the 10-Way forward lamp harness connector (Black) to the camshaft position sensor.
2nd wire is #450 BLK/WHT to ground.
Okay, is the ICM the thing that the coils plug into? There is a plug on the top end of the thing that the coils plug into that has a two pin plug. One wire is pink and the other is black. Is that the connector you are talking about? Also on my wiring diagram it is showing that wire #450 is black, not black/white. If that is the correct connection I am guessing I should spliced into those two wires, run one to the ignition source and the other to ground?
I'll be trying this again this evening so you guys can keep throwing out suggestions all day.
The wiring for the ICM should have been intact in the original harness. You don't need to keep splicing power to various wires in a guess-and-check fashion. You're just going to start a fire.
The ECU needs constant 12v and switched 12v.
Each injector bank needs 12v.
Everything else that needs power will get it from the ECU (ICM, sensors, etc). If they aren't getting 12v from the ECU, then something is wrong and it won't run anyway.'98 Volvo V90 - Ford 5.0 swap in progress
As shown in the diagram above, the ICM also recieves power from the IGN.-Brad-
Originally posted by Canyonero View PostThe wiring for the ICM should have been intact in the original harness. You don't need to keep splicing power to various wires in a guess-and-check fashion. You're just going to start a fire.
Can someone please varify that I am using the right pin to to get ignition power?
Originally posted by bszopi View PostAs shown in the diagram above, the ICM also recieves power from the IGN.
