Still no go. I ran a wire from my ignition wire to the to pink wires just before the plug into the injector harness by the fuel rail...is that correct? I am getting current in them when I turn the ign on. Of all of the wires that I posted not being hooked up I have only hooked up the one that says it goes to the ignition, I ran that to the positive ignition wire on my jeep, and now I have hooked up the two pink wires from the ignition wire on the jeep to the injector plug...other than those three wires the rest are still just hanging out.
I went through and re did all of the pins that were marked as "ECM Ground" there were four of them, they are all running to an 8gauge wire now which is bolted to the firewall under the hood.
In Canyanaro's wiring instructions there are three wires that say they go to ignition module Connector 1, 2, and 3. Do I need to do something with that? Also I have cut the fuel pump relay off of the ecm since I am using a universial relay kit for that. I am picking up the switchable power off of the ignition wire on the jeep as well, I don't think this would cause a problem but you can let me know other wise. i have also tried my other ecm and I am still not getting anything.
When I leave the key in the on position the fuel pump is very audible while in the tank and I am getting a hissing noise coming from the engine bay. Every time I check at the schrader vavle on the fuel rail I have plenty of fuel shoot out (The gauge I have cannot be put on this valve).
Do I need to run some sort of power wire for the ecm? What gives? I could really use some help.
