Guys....OK, my quick look through the wiring diagrams/shop manuals says it should be a plug and play. HOWEVER...I have heard that the 3400 DOHC trans is different than the 3100 trans. True? I assume the ratios may be different...but the PCM should still control it ok, no? I assume the inputs to the PCM from the trans are the position switch, speed sensor, and RPM..... I can see a disconnect with the RPM vs MPH....but is it THAT bad? Is that a showstopper?
HELP! I need to drop a new motor in the Old Lumina, and I'm thinking the DOHC is the motor I want to use.... I have that available, AND a 3400 OHV, but the DOHC is a sweeter choice, I would guess....
Any opinions?
Any opinions?
