I know if i use a 3.1 bottom end with a 2000ish 3400 top end I need custom length pushrods cause the 3400 uses the fancy fulcrum (i think thats what they were called) rockers. but I also found out that if you use a 94-95 3100 top end you dont need custom length pushrods cause they use the same style rockers as the 3.1.
So does that mean I can run a 3.1 bottom end with a 2000+ 3400 top end with 94-95 rockers and i could use the stock length pushrods?
thanks
thanks
