FWD to RWD Fantasy Swap
  • FWD to RWD Fantasy Swap
    Has anybody considered putting the entire FWD assembly in the back seat area of their FWD car? I've been fantasizing about this for a while and am curious if anybody has done it.
    I saw a Corvair guy did one using a transverse Northstar assembly into the back seat area of his 2 door coupe. My car is an '04 Monte Carlo SS and would really be sweet with either the 5.3 V8 or the new 3.9 V6, 6 speed auto and paddle shifters. Would be quite the sleeper if I could afford to do it.
    it's been done.
    Taylor
    1998 Lincoln Mark VIII
      There was a Northstar caddy in the Detroit area, had a Northstar in the front and back. A buddy of mine in Toledo had it in for a paint job. I'll have to check him out and see if he has some pics. I took a OldsToranado drivetrain and built a dune buggy out of it. Bad as hell, all that weight on the back you could wheelie on demand but it couldn't keep up with a well built air cooled VW engine. Too damn heavy.
        Actually, I realize I wasn't very clear in my original post. What I'd like to do is remove the front engine altogether and put it or something else (higher HP)in the rear to create a mid engine vehicle, like the Porsche Boxter.
          reguardless of what you say, that link that I showed you, it shows a Cutlass Supreme with an engine in the rear. Going from that, you could easily do it. The only difference is that you would not have an engine in the front.
          Taylor
