95 Beretta Help
  • 95 Beretta Help
    Hello everyone, new to this forum and need some help. I have a 95 beretta 3100 engine and would like to know which years and makes will interchange with this car ? i've been reading over some of this and you guys know what your talking about,not like the others i,ve talk to. So please any help.For instants I found a 90 gran prix 3.1 for 100.00,will it work.
    You will want anything 94+. But your best bet would be a 96+ 3400 or 00+ 3100.
      bszopi thank you
      what is the difference with the 3400 any thing special. Also is there any diff. with a cavalier,I looked at a few, the engine looks sort of the same but nobody can tell me if it's the same block. I appreciate all your help, again thank you Rick.
        More displacement and better flowing top end (also found on the 00+ 3100s).
        As far as any 3.1L in a Cavalier, no the block is different. It is a Gen2 engine, whereas the 3100/3400s are Gen3 engines. If you want a better rundown of the differences, check out the Family Tree : http://wiki.60degreev6.com/index.php...V6_Family_Tree
          bszopi
          Thank you very much. I feel more confidant now. Greatly appreciated. Again Thank You Rick
            beretta gt
            i have a 90 beretta does the door from 95 fit i need new driver door
              I believe 90 had the old style interior? The door panels might not bolt up without swapping over the mounting brackets and stuff. Also 95 the seat belts are in the doors. I'm thinking No without a lot of work.
                still have not figured this computer stuff i have 89 beretta just replaced transmission soiald 97000 miles need to figure out how to get window on track trying to find new door or replace window door will problely be cheaper HELP
