I HAVE A 1987 CAVALIER RS WITH A 2.8 i WANT TO SWAP A 1998 3.1 FROM A GRAND AM CAN ANYONE GIV ME DIRECTION ON HOW TO DO THIS?
need help
Isn't the 87's TBI?? If so, you might need to swap the harnesses to the 88-93 OBD1 harness or just swap to OBD2 if you want dhp. You'll need to fab up an engine mount I'm pretty sure. Other than that & swapping a few parts and making a few adjustments/alterations it should be straight forward.Lifting my front wheels, one jack at a time.
Originally posted by ForcedFirebird View PostIt's not an easy swap to put a FWD motor in the fbodies. The Camaro 3.4 is an easier swap.Last time I checked, an 87 Cavalier was a J-Body.
Check out www.domesticcrew.com for probably the best writeup on this swap.-Brad-
Originally posted by bszopi View PostIt must be too earlier for you to be posting, cause nowhere in that thread do I see any mention of an F-Body.Last time I checked, an 87 Cavalier was a J-Body.
Check out www.domesticcrew.com for probably the best writeup on this swap.Maybe too early, or the caps lock, could have sworn it said Camaro RS
Originally posted by rlue View PostI have the whole 1998 Grand Am so I can use the wiring out of that if it will work. Will the Tranny from the Grand Am fit in the Cavalier it may be a fourspeed auto?
Ok you need to do more research. You seem like you have NO idea what you are doing (dont take it the wrong way) . You'd hate to take apart a running or easy fixable car then in the end have to junk it and the donor car because it is way above your head.Lifting my front wheels, one jack at a time.
