1998 Chevy Malibu- small port 3100sfi, 4t40e 3.05FR
well i finally blew my 3100 all over route 28 at 70mph, nice smoke show and i got to see parts bouncing down the highway behind me... oh and some lady thought i was on fire so the truck showed up after they hard already passed me, they said they were looking for a fireball and didn't think it was me
anyways, its time to get serious about a 3500 swap, im trying to get a list together of things i need and i also need to know if this is even a bolt in swap with the exception of wiring
i know i need-
TCE crank sensor
DHP PT
TB adapter
TCE TB
now will the block mount up like my stock setup? what would/should i do for injectors? guessing maybe 3400 injectors and fuel rail with an aftermarket fpr (using the an adapters from the store) will be good enough in stock form? exhaust manifolds from an epsilon bu should fit my bu right?
ive searched and have been researching this for some time but i just wanna double check my work... other than the stuff i mentioned and wiring this should all bolt up though correct?
i know i need-
TCE crank sensor
DHP PT
TB adapter
TCE TB
