I'm putting a 3.5l from a 2004 Malibu into an MGB backed by a GM T5 and using the stock 3.9 gear that's in the car now. The engine that came out was driven by a distributor and a Weber so there is nothing to salvage.
I've been reading the forums and can see all the 'discussions' about aftermarket, ODB (1, 1.5, 2) but they all mostly talk about swapping one efi engine into a car that already has an ecm and how to tune it a bit differently. I'm starting from scratch and am interested in what would make the most sense considering that this engine is NA but the next one will be SC'd (and if I can I'd rather not have to swap out and rewire the ecm).
I'd like to be able to swap tunes based on what fuel I'm running 87, 93 or 104 and where I'm running.
I'm not especially worried about trying to keep some random emissions tester happy as the car is to old to need to go in for a test and it'll spend what few hours a year split between a track and tooling down back roads. (No I don't want to spew noxious fumes but I don't need to artificially choke the engine just to get a sticker)
Since the car never had EFI it never had a high pressure fuel system so I need to build that into the system too (again I'd rather not have to replace all of this with the next engine). I'm planning on putting in a fuel cell so I have a blank slate with that too.
I'd like some pointers to threads or to new discussion on these two topics.
Thanks
ps oh yeah I'm putting monster Wilwood brakes and F1 rubber under it all to make it stop too
Thanks
![Wink](https://www.60degreev6.com/vb5/core/images/smilies/icon_wink.gif)
