I have a neighbor with a Grand Am Gt 1995 with a 3100.The motor in it turns over 3/4 of a turn(By Hand with 3/4 drive breaker bar and socket on crank pulley bolt clockwise) won't turn 360 degrees.It is binding up and I came to the conclusion that either a valve is in the cyclinder doing this or something is in one of the cylinders.I found one broken valve spring I think on #5 cylinder(the middle one front of motor Intake Valve).The question I have is obviously I may need to replace the engine 162,000 miles on it.What would I need to do to swap the 3100 with a 3400 out of a 1999 grand am?.Are the Harnesses the same?...injection?..computer?.Any help would be appreciated..I told my neighbor that this 3100 engine in his car is notorious for cracked and broken cam shafts..which I suspect to be the cause of the broken valve spring and probably a thrown valve.
PS.also would the original transaxle fit on the 3400 or would I need the Transaxle that came with the 3400?.
