Ok im looking at swapping to a bigger motor from a 3.1 trying to get some info on the 3900 V6 in the G6. Has anyone worked with these yet. I know its a relatively new motor, just trying to decide if i would be better going with a 3400 or 3500. Main main questions are Does the 3900 have an aluminum block. I plan to build this motor from the ground up and an aluminum block is desirable. Also I have a 5 speed manual now. What 6 speed fwd trans are available? I know the G6 has an available 6 speed, but i havent really seen it available before in a fwd gm car.
The car to be modified is a 1994 Chevy Cavalier Z24 Convertable
Current setup is a 3.1 MPFI and 5spd Trans, Right now the rough plan is going to a built 3900 60° V6 with turbo's and a 6 spd any input is appreciated
