I think I need help
  • I think I need help
    Ok, Ive been looking but maybe Im not understanding anything, I used to military engines and dirtbikes but Im looking to but a 3.4L into my wifes 1984 2.8L Camaro after I was able to talk her out of getting a 4.3L. So what I gather is a 3.4 from a 93-95 will fit, and all of the previous parts will bolt on like the tranny, intake, exhaust, timing cover dampner and the brackets and accessories. So Right now I have been looking for an engine and the only things that I can find are 3400 or D.O.H.C. I do know what a Dual Over Head Cam is but is that what the 93-95 is or is that a completely different engine. Any help on straightening out the parts list that will fit and that I will have to get and some clarification on the engines that I find to the engine that I need.
    A GOOD FRIEND WILL BAIL YOU OUT OF JAIL, BUT A TRUE FRIEND WILL BE SITTING NEXT TO YOU SAYING,"DAMN THAT WAS FUN."
    you need a 93-95 rwd 3.4l from a camaro or firebird. a 3400 is a fwd engine and is far from a bolt in, same deal with a dohc. the 3.4l rwd motor may be a bit more dificult to find being its a 3 year olny motor and it was only in 2cars.
      eh
      ill sell u my 94 camaro with a 3.4 :P $1550
        your looking for a 93-95 3.4. rpo code is L32, vin code 's', came in camaros and firebirds.
        treat it just like a short block replacement for your engine. use the 3.4l head gasket. everything else just goes right back on the car the way it came off. also make sure yours doesnt use the mechanical fuel pump, im not sure if 84 camaros were carbed....
        2012 Chevy Sonic Turbo 6spd
