Does anyone make an adapter to do this? I mean to go from the vertical mount EGR to the horizontal one? Or has anyone had success doing this?
I've caught one more hitch I wasn't planning on as I thought it would be doable based on comments from someone else a while back, but I'm really at a loss as to how to make it work.
My car stock, had a vertical mount 96-99 style linear EGR, and I'm trying to use the new horizontal mount 00+ EGR (along with plenum, LIM, heads) on my older L82...
Now I thought it might be possible to just swap the pipe on the exhaust manifold and then maybe use the new pipe and all would be well (?). But the pipe is a LOT harder to get off than it would seem, so I don't think I can got that route. (I wonder if running the manifold up to temperature would make the nut easier to turn?).
Anyway going by comments by a user on a Grand Am forum some time ago, he claimed that he easily hooked up the old EGR pipe to the new EGR doing this:
"The new EGR's are side mounted, while 94-99 was top mounted (yes 99 manifolds differ from 00). Anyways all i did was tighten the old nut where the tube hooks to the manifold on the back of the new egr and that holds the old bracket up tight against there. Perfect."
Although I have no idea how he did that because I tried turning things every which way and nothing lines up. The old bolts are also way too long and only half-threaded so I don't get how this guy did this at all. I PM'd him but the post was 2 years ago and he doesn't even have a Grand Am anymore I don't think.
There's two threaded holes on the old-style plate that connects up to the UIM where the long bolts thread through and connect all of the UIM, EGR and pipe together. On the 00+ EGRs, the EGR bolts to the plenum with two bolts, and then the pipe from the exhaust bolts to the EGR with one bolt.
The only way I can see making the pipe fit the new EGR is if I were to drill a hole in the plate and use a shorter bolt and then secure the EGR to the plate that way. Only a couple problems--the old EGR inlet for the exhaust pipe was slightly smaller meaning the old pipe is "loose" in the new EGR
I was thinking maybe wrapping some muffler tape around the pipe end would make it fit better, would that work? Is muffler tape high enough heat bearing to do that at the EGR?
Also I don't have a drill bit large enough on hand at the moment which makes things worse
The only way I can even imagine what that guy did was if he used a shorter bolt (and not the original one as he said) and basically "clipped" the bolt head such that it just caught the bracket and held it on to the EGR. However this does not seem very secure and again does not solve the pipe diameter problem.
If anyone knows if there is such an adapter made, I would appreciate any info on it. I'm thinking if there is an adapter I can just jerry-rig it like the above for the time being and then get the adapter later...
If there is no adapter I would probably try my method of drilling a hole and using muffler tape on the pipe, but again no drill bit right now
Very frustrating! And, I think it would be pretty darn difficult to drill a hole in the plate once I install the head in the car (meaning if I jerry-rigged it, then I'd probably be stuck with it like that).
If anyone has any advice/tips/info on how to make this work, I'd really apprecaiate it!
