I'm to the point of working on the wiring for my swap, and I can't ID these plugs in my GM service manual...
I have a 2002 Grand Am 3400 harness strung to the engine and using a 99 3400 harness for scrap wire. What plugs are left on the 99 harness are ones that are not on the 2k2...
I think that has something to do with the brakes... I have a similar one already hooked up to the brake booster...
I have no idea, but there's a somewhat similar one on the 2k2 harness:
And lastly, I don't know if the following 2 plugs are in a seperate harness or what, Ignition control module, C2:
(where the missing plug is)... is that even needed?
Also, the crankshaft position sensor B (the plug on the firewall side of the engine), the harness socket isn't there, and splitting the harness back doesn't show the wires for either the ICM2 plug or the CKP sensor... did something change in 2002 to eliminate those?
