Some of you know I have a spun rod bearing in my Firebird 3.1. I found a solid 2.8 TBI from an 86 S10, and was wondering what would be needed to convert it so I can keep my MPFI?
Actually to be more specific tell me if I am missing something :
use the 2.8 flywheel
use the 3 piece manifold from the MPFI, will it bolt to the gen1 heads?
oil pressure sender is on the block (2.
, not the oil filter adapter(3.1)
If I use the serp belt, do I need to use the 3.1 timing cover (reverse water pump)?
Any other sensors in a different location?
I know I am downgrading, but I'm not concerned about the performance at this point, just got to get the car working and I will build the hybrid out of the 3.1 block to put back in later.
